Have a 91 3door escudo, with the cheap vitara lift which has started making a clicking noise from what i assume to be the front left and I can't pin point the problem.
Hard to explain, but its not the cvs, I replaced the whole half shaft the other day anyway cos the boots were split and also cos it does it in 2wd and 4wd, but isnt constant, comes and goes. Usually at its worst after moving off from coming to a stop.
Speed of clicking is proportionate to speed, Have stripped and repacked the bearings, nothing is rubbing/catching on the wheel/brakes anywhere, and I am just stumped!
Hoping someone else may have some ideas as to what it may be.
Undiagnosed clicking noise?????
Re: Undiagnosed clicking noise?????
Has it got auto hubs? Its not them making noise at all??
Stupid question I know but seeing youve been workin on the front I assume youre front wqheel nuts are tight. Have you checked the rear wheel nuts lately?
Sounds strange but Ive found loose wheel nuts before when other mechanics had diagnosed the rear diff, cvs, wheel bearings, among other things
Didn't barbie drive a jeep??
mine was doing something similar, it was not an ongoing clicking tho just a one-off click whenever i started or stoped / slowed down or accelerated or hit decent bump etc... sounded like it was coming from front left but turned out to be trailing arm bushes on rear diff.
Got superwinch manual hubs and the all the wheels have been on and off several times. jacked the whole vehicle up on stands and had all the wheels running, and nothing, then bugger me drop it down and go to leave the drive and there it is clicking away again!! (and no there aren't stones stuck in the tread)
- mudlva
checked your ujs not binding up are they? as it only started after you lifted the vehicle
