4d56 compression test
wildplumdx
Post by wildplumdx »
ok so i got a compression tester and it says i have to isolate the fuel from entering the engine ie says from the fuel shutdown solenoid ? was going to just disconnect the fuel line but i don't wanna crank the pump over dry encase it damages it or something of the like ?
wildplumdx
Re: 4d56 compression test
don't worry sussed it got 420 psi across all cylinders at 10 revolutions, wrapped!
