Terrano Tappets
toby1
Stropper
Terrano Tappets
Post by toby1 »
How do? I am looking at a 92 2.7 non turbo but the tappets are a little noisy. How much is involved in tuning them up? I have no probs doing this with a petrol car. Much difference with a diesel truck :?: Any info helps :!: :D
albundy
Rolly Polly
Post by albundy »
you already own this truck, or you thinking of buying it :?:
toby1
Stropper
Post by toby1 »
Thinking of buying. Rust free and low k's for age. If it's indicative of more serious probs I might hold off and I'll be sending it through the AA too but thought I might get a heads up :!:
JTop
Post by JTop »
Tappets are simple and a common thing on the TD42/TD27, possibly a weak oiling fault to the valve gear but no long term ill effects although they can wear the rockers and rocker shaft.
For rust have a very hard look under the rear seats and from underneath arround the seatbelt anchorages, any blistering means no WOF and a $2000 repair bill. You have to replace the complete floorpan in the rear and these vehicles are prone to this fault. Check for BlowBy from the oil filler cap and white smoke on cold start as possible bore wear and oil leaking from arround the Turbo.
A good truck but with limited aftermarket parts available in NZ
J Top
toby1
Stropper
Post by toby1 »
Thanks Jtop, I will follow your advice. Is this rust issue a manufacturing issue that I can fix with a regular maintenace regime (rust proofing) :?: If it's model-wide I would suspect a design fault such as a drain position or exposed joint etc.
dctecho
Post by dctecho »
The rust problem in these vehicles can be major,but if the rust is only minor around the seatbelt anchor points then a support bar can be added, all the relavent info on this site.http://www.lvvta.org.nz/index.html
just thought i'd mention this i know of one of these purchased for $800 as the previous owner was told the floor needed to be replaced,the vehicle was repaired for under $1000. (thats a cheap 4WD
albundy
Rolly Polly
Post by albundy »
Too right. Don't buy original Nissan as they will really put a whole in your pocket. Find a good Nissan wrecker and stick with him. Mines excellent, never lets me down. finds the part at the right price all the time.
Al
DieselBoy
Post by DieselBoy »
JTop wrote:Tappets are simple and a common thing on the TD42/TD27, possibly a weak oiling fault to the valve gear but no long term ill effects although they can wear the rockers and rocker shaft.
Correct
Its a common fault with the TD series engines. The rocker shafts wear premirturly.
This is more common on the the TD27 than the TD42. I had a terrano, it had noisey tappets, and i ended replacing the rocker shaft, same with the curent TD42 in my safari.
Its very common. Its $270 for a rocker shaft for the TD42, and about that same for the Terrano.
Adjusting the tappets are the same as that on any petrol engine that has the same set up with a lock nut and adjuster. All you neet is a flat head screw driver, 10 mm spanner and feeler gauges(plus something to turn the engine over with.
Looking retrospectively, i should have just adjusted the bloody things untill they were as close to the correct tolerance as i could get and lived with it. :wink:
Hope thats usefull :lol:
toby1
Stropper
Post by toby1 »
Definitely helpful, thanks everyone, will update as I progress :)
RICHR
Newbie
Newbie
Post by RICHR »
Hi,
Sorry to bring an old topic back from the dead but anyone know what the correct tolerance is for the tappets on TD27T.
Thanks
Richard
95 Nissan Terrano 2.7TD
90 Nissan Pulsar GTi-R
88 Mazda RX7 SAVANNA
