auto to manual hubs
auto to manual hubs
is it as simple as just swapping them out for manual one...???
Re: auto to manual hubs
Yes, just double check the spline count is correct.
Ph 0212078472
Ph 0212078472
sweet thanks just wasnt sure if they'd have there only different axles
Quite often the circlip goes in a different place with auto vs manual so make sure you get that right.
Factory auto normally has circlip in close to cv while manual often has circlip right near the end of the sub axle.
ie there is 2 grooves in the stub for the circlip.
oh so true , learned the hard way
