Saving the whale
bobrocket
Saving the whale
Post by bobrocket »
My mission that started last year - Now that I've figured the photo thing
After convincing the wife I need a new car, I was offered a really cheap GQ destined for the wreckers, It had done the rounds and apparently needed severe $$$ thrown at it for rust repairs + some minor fixes for a WoF.
---Insert tui ad ---
Some grinding + practice wielding from UBZ, we managed to save the roof, luckily we had no cutting disks or it could of become a ute
There were lots of little things that needed doing but the guy thought it was a right off because of the rust, took it back after the weekend (3 days later) - one of those happy moments. - safari with WoF
Then it begins........
Rear Gaurd Chop
Extractors - Hmm..........Brought them off T/me nice and cheap but was a premature impulse thing, they had been made on the truck and removed while still attached to the motor, so now I had cool extracters that don't fit - I only figured this after many hours of trial and error, after a little chop I quickly figured that the pto shaft was in the way so once again busting out the grinder, had some bends put in and happy again
So then the alternater starts leaking oil, this completely stumped me?????? I'm not an expert but I'm pretty sure this just aint right. Out it comes, pull it apart, figure it out, completly fark it then send it in for repairs, this is about the time I got myself a manual........
Add snorkel, tyres and a 2inch lift and then its time for a holiday,
off to the far north to introduce the wife to car camping.
And how to use the winch? sort of...
Then someone explained to the wife that if she was a bit nervious she should get out and take photo's, because every boy likes cool photo's of his truck - except for some reason I seem to have lots of photo's of Deiselboy's cruiser.
Jumping a whale :( That cost me a shock and an axel seal,
How not to change an axel seal, bash a screw into the seal so you have something to pull on, great idea untill someone knocks the screw down the axel, into the diff, we could feel the screw on the inside by putting a finger in the drain hole, yes there's a lip on the inside, after "a while" it came out, haha then we realised the seal was the wrong size but quickly fixed.
On comes the bar work, best thing for rear bars? after looking at tube options I decided on 5mm channel steel, something nice and solid. it kind of gives it a nice symmetrical look with a touch of anger.
Then there's the trick of learning how to wield?, After doing lots and lots of grinding it seemed to get better, faster.
Off to woodhill for a play, go the navi...........He thought we were going for a hoon up the beach :D
$50 at wash world + hours of cleaning sand set like concrete, it's like a one night stand ending up with twins?
Custom diff breathers, cost about $30 for hose and fittings and the filters were $10 each at super cheap
All it needs is a bit of plate to mount the filters to make it look pretty.
Brought some bullbars off trade me, they had been damaged but solved the problem of more steel on an already heavy whale, a couple of plates to lift the bars to match the body lift, chop, chop, grind to fit the winch,
the next plan is to move the winch back and up, but havn't quite got that figured out yet.
bobrocket
Re: Saving the whale
Post by bobrocket »
Bullbar pics
badnuz
Post by badnuz »
nice work, good to see these sort of build threads, bit of homework, bit of research, bit of cutting (opps, wrong place) bit of welding etc etc :)
are you into the touring camping scene?
rokhound
Post by rokhound »
good stuff. :P
bobrocket
Post by bobrocket »
The plan was for a capable touring type wagon, something good off road but also usable to drive everyday.
A lot of my off road stuff is done through work, access to sites etc....work trucks are great, sometimes if we're lucky we even get a rental :D
badnuz wrote:are you into the touring camping scene?
Was for a bit, time seems to harder to find, to get away these days so its been mainly day trips, local play spots, got a sneaky overnight planned soon so hopefully that pans out.
Bulletproof
Post by Bulletproof »
Good stuff
It is a lot more satisfying when you do the work yourself instead of just having a cheque book and paying others to do it.
Well done
Cheer Richard
Never say die, up man and try
petefj40
Ms Daisy
Post by petefj40 »
Bulletproof wrote:Good stuff
Well done
Cheer Richard
Yep. But not everyone is lucky enough to know what to do aye.
Nothing wrong with employing people to do the work? :roll: That's how some people make a living. It puts food on their table Richard.
But yeah, well done.
:D
niblik
Post by niblik »
nice whale.. :!: 8)
Andrew1706
Post by Andrew1706 »
Surprised I haven't seen you up the beach at some point 8)
bobrocket
Post by bobrocket »
Finally got around to making a mount for the filters (diff breathers), something to cross off the list.
Also made a mesh cover for my snorkel, Its amazing how many bees, wasps, bits of gorse......etc get sucked in. Just used the mesh from a sieve I found in the kitchen, a bit of rubber tape, I thought it was a nice $2 fix.
Started making brackets to give the rear bar a lift to match the body, I'm thinking it might look a bit funny so been toying with ideas for some sort of cap over the chassis, dunno yet? see what happens after a few tins of brain juice.
muddyhilux
Post by muddyhilux »
looks good mate,nice wirk on the mods,and definetly nothing wrong with learning to weld,it takes practice but its worth it when ya see the end results ae
UBZ
Post by UBZ »
[quote="]nothing wrong with learning to weld,it takes practice but its worth it when ya see the end results ae[/quote]
Yeah ,carefully ground and hidden beneath 5 coats of paint :mrgreen:
muddyhilux
:lol: yeh nothing wrong with that :lol: ,it still looks good officer :lol:
bobrocket
Post by bobrocket »
UBZ wrote:Yeah ,carefully ground and hidden beneath 5 coats of paint :mrgreen:
muddyhilux wrote::lol: yeh nothing wrong with that :lol: ,it still looks good officer :lol:
+ a little bog to fill in the holes,
the quarter panel holes are strategic drain holes aye UBZ :mrgreen:
bobrocket
Post by bobrocket »
Finally got some new feet :D
Only minor front guard adjustment required to stop the rubbing (maybe more after a good flex?)
bobrocket
Post by bobrocket »
Also after a few random bits, thought I might get lucky here,
tried a few wreckers but they don't seem to be interested in dealing with small stuff like this
The window squirter things on the bonnet x 1
A front passenger side monsoon,
A tacho sender,
Cheers in advance
Heath
Post by Heath »
bobrocket wrote:Image
Are those back windows std or something you have done? Got a mate with sliders he wants to change to fixed.
DieselBoy
Post by DieselBoy »
Looking REALLY good!!!!
Just about ready for the summer holidays trip :D :D
bobrocket
Post by bobrocket »
Are far as I know the windows are just std,
Was talking with UBZ the other day about that, apparently I can only go for maybe a week max and I have to go by myself, what is it now?, 9 mths since the last trip.
DieselBoy
Post by DieselBoy »
Hmmmmmm, a week IS better than nothing :D :D
Never mind, ask UBZ about an even better trip to the deep dark south later next year, you DON"T wanna miss that :D :D
bobrocket
Post by bobrocket »
Might of been a little to subtle about the 9 mths thing :wink:
DieselBoy
Post by DieselBoy »
bobrocket wrote:Might of been a little to subtle about the 9 mths thing :wink:
No, I got it all right :lol: :lol:
corosafari
Post by corosafari »
nice work Bobrocket, been a few changes since I last seen ya truck.
Interested to see how tacho job goes, I have just purchased a pipe bender and tig/stick welder to get into some bar work at home workshop.
Im still feeling a bit thick to try photo thing again, got them on file for a rainy day.
Keep up the good work.
bobrocket
Post by bobrocket »
Did a few rust repairs to the beast, some minor panel beating and installed new window squirters :D
I thought me and UBZ (and his ginga) did pretty well for a weekends effort :mrgreen:
bobrocket
Post by bobrocket »
Bugger......the squirters just clean the back of the wiper :(
sibainmud
Post by sibainmud »
bobrocket wrote:Bugger......the squirters just clean the back of the wiper :(
They can be adjusted. Use a welding torch tip cleaner, poke it down the hole and use it to aim the jet at the right place....or.....
go faster :twisted: then the water got no chioce but to hit windscreen :lol:
bobrocket
Post by bobrocket »
Haha..........1min later a pin fixed that
bobrocket
Post by bobrocket »
bobrocket wrote:Did a few rust repairs to the beast, some minor panel beating and installed new window squirters :D
We ran out of primer so we just beat it with smurfs :mrgreen:
sweet looking paint job dude
top job
