Hey there,
I have a LN65 with wellside which has a tray lid (made of plyboard covered with tread plate, its damn heavy).
Problem is that the lid has been attached with a normal screw type hinges, which means it is permanently fixed and can not be easily removed.
I would ideally want the lid to be removable, so some days I can have the tray lid on and others it might be off. What type of hinge do I need?
I was thinking something along the lines of a U type hinge that has a “screwable lock” on the top (to stop it falling off 1/2way down a mud track)
I probably havent explained it too clearly and will post some pics when i get home tonight.
Cheers for your help.
Ute Lid Tray Hinge - What type do I need
Re: Ute Lid Tray Hinge - What type do I need
maybe intsead of a hinge you could use two small hoops and hook in the lid
DIRTY OLD HILUX
022 519 7700
022 519 7700
I got a Landrover (stop laughing
) that has some hinges that work like that,sort of shaped like a C it allows the bonnet to be raised up to normal height and if you fold it right up to the screen you can remove the whole bonnet.
I may be be able to take a picture if you want?
I may even have a spare set in the shed if you are keen(not 100% sure)
mylux wrote:I got a Landrover (stop laughing![]()
Yea thats the kinda thing I was thinking of. If you could take a photo that would be fantastic.
trailer tailgate hinges, from Supercheap, TWL or similar
