lower control arm length for 2" lift
y60 safari driver
can any one tell me what length you extend your lower control arms to to twist the diff back after a 2" lift
Re: lower control arm length for 2" lift
I've got +16mm lowers for a 3" lift, SWB, only because shocks were hitting springs, BUT then I had to cut rear guards to stop 35 Simexs hitting rear wheel arch.
y60 safari driver
i'm only running 33" so shouldn't have that issue i dont think
SWB or LWB? for a two inch lift you shouldn't need to change the arms, for a SWB you may have to drop the rear gearbox mount using spacers, for a LWB you shouldn't have to do anything.
nuts
- Location: somewhere arround westcoast offroading usually
shouldnt need to alter anything untill you get to a 4 inch lift i thought
