lower control arm length for 2" lift
Posted: Mon Aug 02, 2010 5:49 pm
by y60 safari driver
can any one tell me what length you extend your lower control arms to to twist the diff back after a 2" lift
Re: lower control arm length for 2" lift
Posted: Mon Aug 02, 2010 8:05 pm
by mudtroll
I've got +16mm lowers for a 3" lift, SWB, only because shocks were hitting springs, BUT then I had to cut rear guards to stop 35 Simexs hitting rear wheel arch.
Posted: Tue Aug 03, 2010 5:42 pm
i'm only running 33" so shouldn't have that issue i dont think
Posted: Tue Aug 10, 2010 10:20 pm
by Dak
SWB or LWB? for a two inch lift you shouldn't need to change the arms, for a SWB you may have to drop the rear gearbox mount using spacers, for a LWB you shouldn't have to do anything.
Posted: Fri Aug 13, 2010 10:25 am
by nuts
shouldnt need to alter anything untill you get to a 4 inch lift i thought
