32s on a Samurai
For all Suzuki related topics
suzookyman
32s on a Samurai
Post by suzookyman »
Anyone out there running 32inch tyres on their SJ or Samurai?. I have a SJ410 transfer case (from a ute) in it.Hows the gearing?
cheers Al
meatc
Re: 32s on a Samurai
Post by meatc »
I got 32 10.5 simexs on mine. Cant really help with gearing as I'm running hilux axles and a different motor/box too.
I would suspect you may need to combine the 410 and 413 transfers and make a rock lobster for lower gearing. Expect to have to do guard cut and lift to make them fit too.
suzookyman
yeah got plenty of lift just wondering if the 410 t/case can take 32s.Its currently running 31x11.5 mudzillas but they are a bit spooky in the wet so was thinking of maxxis bighorns.
Al
suzookyman wrote:Anyone out there running 32inch tyres on their SJ or Samurai?.
http://www.offroadexpress.co.nz/Forums/ ... 18&t=22123
turoa
Pyro Junior
Post by turoa »
Have 32" wranglers on my bro's 410 flatdeck (running an 413 gbox). They fit with 40mm extended bumpstops and a whole lotta guard choppage(but now got OME lift springs). His ones running a 4age and its down to first gear to spin the tyres up (mind you it pulls second if you get it goin in first and then dump it into gear). Used to pull 2nd easy with smaller tyres on. Id stick to 31's if you've still got the stock motor
UBZ
Post by UBZ »
A 410 case is 12% reduction on high and a little on low. You need a 4.16 or higher ratio reduction gears on stock axles to run 32's offroad .
My very tired 1300 spins 31's no problem with 4.16 gears
mroffroader
Post by mroffroader »
I have 5.12 ring and pinions in my diffs out of the front of a vitara...pretty cheap low gearing :D
UBZ
Post by UBZ »
mroffroader wrote:I have 5.12 ring and pinions in my diffs out of the front of a vitara...pretty cheap low gearing :D
True. 5.12 diff r&p will spin tyres but no reduction in low range . Combination of 4.6 r&p and transfer gears would prob be best .
zukmeista
Post by zukmeista »
Yep, from what I've seen on the net the best combo would be 4.6 vitara r&p's and the 410 tbox.
suzookyman
Oh well looks like im on the hunt for escudo r&p, is the manual or auto the better option-hopefully manual as i already have one
Al
zukmeista
Post by zukmeista »
Here is a link to give you an idea of what r&ps you might have there:http://bbs.zuwharrie.com/content/topic,15579.0.html
P.S. Are you going to Pouto?
suzookyman
zukmeista wrote:Here is a link to give you an idea of what r&ps you might have there:http://bbs.zuwharrie.com/content/topic,15579.0.html
Nah cant do Pouto,working.Thanks for the link,cheers Al
zukmeista
Post by zukmeista »
Glad to help. :wink:
Return to “Suzuki”
