performance 1hdt
uwish
performance 1hdt
Post by uwish »
hi all
what sort of mods can you do to get more performance out on these motors the truck is a 1994 with 110,000kms on it it has a computer chip.
i was thinking 3" exhaust
a front mount intercooler
them was going to play with fuel and turbo?
is there a bigger turbo you can bolt on?
what mods can you do to diesel pump?
also where in christchurch can anyone recomend to get exhaust manifold flanges cut out of steel and stainless so you can make your own flows or turbo maifolds or water jacketed exhaust?
also if anyone has a td42 head that they are goin to throw out id be keen or swap for beer
andrew007
Re: performance 1hdt
Post by andrew007 »
hi m8,try autobend,they will sort out exhaust bits u need.
4WDbits
Post by 4WDbits »
3 inch exhaust and intercooler are a good start, instant gains from a few bolt ons. Put a EGT gauge in it and wind up the fuel slowly.
Supra CT26 cold side is good, GT2860R bolts straight on I think.
Marine version of the motor come stock with 320hp.
badnuz
Post by badnuz »
safari have just released new bolt-on turbo upgrades with a TD06, added to their range of intercoolers they have also released a complete exhaust system.... expect to empty your wallets easily thou :shock: intercooler kits $3800, turbo kits $5900, exhuast sytems $2600 :shock:
i had my CT26 rebuilt by alltech in Auckland with T04E internals, helps it spool up faster, add to this a 3" mandrel bent exhaust from my local muffler shop, and more fuel wound into it and it goes good....
i also belive that changing the anoroid pin in the fuel pump for one from a mitsi 4M40 helps with of boost overfueling and can flow more fuel for on -boost than the factory unit
smurf182
Post by smurf182 »
4WDbits wrote:Marine version of the motor come stock with 320hp.
The Yanmar version would have to have a completely different induction and fuel system to make that kind of power.
ie. around 30 pounds of boost
mudzilla
Post by mudzilla »
And an ocean full of water to keep it cool.....
uwish
Post by uwish »
so the cold side of a supra ct26? what turbo does the 1hd come with? also any point in changing the dump pipe is there anything to be had there?
