413 engine into 410
413 engine into 410
Gidday guys. Will a 413 motor and box drop into a 410 without any drama? engine mounts, shafts etc the same?? Ta
Re: 413 engine into 410
No , no and no.
Engine mounts are in different locations ,tunnel needs to be moded to fit the five speed gearbox, 410 transfer case has a different bolt pattern to 413.
What is wrong with the 970cc?
LR110 ..... LJ50 project
suzookyman
UBZ wrote:No , no and no.
Thanx. I have a 410 that had a swift GTI motor in it but was removed b4 I got it, therefore the bracket on the chasis have been changed for that. I can get a G13b motor and box but have 410 ute t/box. U know the drill, trying to put together a million dollar truck on a shoestring.
- Rotazuk
Let me guess , it was Pink
To fit the 410 t/case into a 413 you can either change the input flange on the t/case or change the jack shaft uj end . I am pretty sure the uj's are the same between the 410 and 413 ( I know a 413 vitara and swift are all the same ) . I think thats what was in there before , a 410 t/case and a modified Jack shaft . If it was a pink 410 a g13 should bolt in as the gti block had factory 413 mounts on it .
Chris
Chris
Rotazuk wrote:Let me guess , it was Pink![]()
Chris
Has some one started resurrecting the lil piggy?
Yes, yes and yes; it's pink and been in the shed for too long.
How much modification required to the trans tunnel? Heavy hammer or cut and weld?
Ta
Ta
- Rotazuk
UBZ wrote:,tunnel needs to be moded to fit the five speed gearbox
This was running a 5sp gearbox , no modification to the tunnel will be required . you will see the shifter hole has been cut out a bit more , either fore or aft , can't remember .
Chris
Great, I'm running out of excuses now
so time to get on with it. Just need some shocks and some time.
Bring back lil piggy.
But it has to stay rank pink and you have a lot to live up to
UBZ wrote:Bring back lil piggy.![]()
But it has to stay rank pink and you have a lot to live up to![]()
Is that a beaten patrol I see in the back ground
Tunnel was cut (hacked) to clear 5 speed gearstick.
This could be an embarrassing thread, It was originally built on less than a budget
and the rank pink was toyota forkhoist red in a can.... that was obselete.....
lilpigzuk wrote:It was originally built on less than a budget
But still gave V8 crusiers a run for thier money
Click for Vid
I remember when I was a kid watching that thing.
Maybe thats why i like zuks
Lubrication Specialist
Lubrication Engineers
Maybe a change in plan
Found someone with 3x vitara/escudo motors sooo.... Can anyone tell me which is the best model for offroad in a 410: 8 vs 16 valve, fuel injected vs carb, ... Any advise appreciated thanx.
unadunted wrote:Maybe a change in planFound someone with 3x vitara/escudo motors sooo.... Can anyone tell me which is the best model for offroad in a 410: 8 vs 16 valve, fuel injected vs carb, ... Any advise appreciated thanx.
8V better torque then 16v, but 16v has better power I'm told. Carb is easier (use std fuel pump) than injected, but not as good on angles due to position of float in the fuel bowls I believe (prone to flooding and stalling).
and you can get a cam regrind done to a just about mild and it works best on the 16v. fair rockets. and its only about 150 bucks.
i have found the carb to be great.ot a problem at all with it.
