over drive cheper to run on or off
daniel1233
Post by daniel1233 »
Hi all i have a 96 1kzte auto surf is it cheaper to run on over/drive on or off around town cheers daniel.
Re: over drive cheper to run on or off
a hundred or so rpm less here and there is less fuel you burn :D
Ginzu8
Post by Ginzu8 »
I normally take it off at the lights and push the button back in when my car accelerate off the mark.. I believe that you will use more fuel if u use over drive when u move off from stationary. But thats just me.. :D
kbushnz
Post by kbushnz »
OD doesn't come in until you are up thru the gears..
So from the lights has no effect.
OD is basically 4th gear .
I find that at 50-60kph the truck seems to labour a bit with OD on.
Turn it off and it drops down a gear. Revs come up.
Calvin
tallsam66
Post by tallsam66 »
I only use my over drive when im driving over about 80km on the flat.
Its better if you rev a diesel a bit as opposed to having it labour.Reving it will keep your EGT & trans temps down.Same as using low range when doing any slow 4wding.
Ginzu8
Post by Ginzu8 »
If OD doesnt come in till its up thru gears ? why does my truck feels like its pulling better from stationary to speed when its OD is off compare to if OD is on?
DieselBoy
Post by DieselBoy »
Ginzu8 wrote:If OD doesnt come in till its up thru gears ? why does my truck feels like its pulling better from stationary to speed when its OD is off compare to if OD is on?
It isn't, its just your imagination :lol: :lol: :lol:
Fuel economy in a diesel is all related to the position of your foot on the accelerator.
If using OD around town means that you don't have to put your foot down as far on the pedal to maintain a particular speed, then use it.
If you have to put your foot down further to maintain the speed after switching OD on, then don't use it, it's is less economical.
Ginzu8
Post by Ginzu8 »
I see. so i wont bother using OD from now on unless i am on the high way.. Learn something everyday :)
tweake
Post by tweake »
you sure you don't have a pwr button ? ie power button which changes gear shifting pattern so it lets it rev out more so you can take off faster.
afaik on those surfs OD is just another gear. some of the toyotas are so low gear geared you have to have OD on to get over 80km/h ! LOL
i would just leave it on unles going down steep hills and want the gearbox to drop a gear to hold you back.
mudlva
Post by mudlva »
my surfs OD is always on except when pulling a trailor up a decent hill then i turn it off just befoore the bottom of the hill to assist in keeping the revs up.
regarding full eco usage with only needing to toe the gas peddle around town with OD on it has to be using less fuel then with OD off and the peddle a little further down, makes sence realy,
1 note thou is that if you are after quick reactions then the motor will be more sluggish in OD and have to move down to second rather in drive moving to second
just my 2 cents worth anyways
Ginzu8
Post by Ginzu8 »
yup i am talking about the OD button not power button.. just feel more sluggish withe OD on..
