iv got a SWB 2a which is currently set up for a canvas soft top. how hard is it to fit a single cab hard top? can you just drop it on and bolt it?
fitting a hard top to a Land rover series 2a
Re: fitting a hard top to a Land rover series 2a
Yep, simple as its all bolt off bolt on stuff.
sweet. got to find a decent one near auckland now.
Offroad Addiction TV
- Landy Rover
Make sure you get the rear mount rail that goes accross the rear. I had to make one using angle iron when I changed mine from full hard top to truck cab.
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
are the cab parts the same size for a 88' and a 109?
- Landy Rover
I think the rear wall is further back on the 109s, thats why you need that rail.
ok, thanks. as long as it fits with the rail thats fine.
