Alternator Problem?
captin stu
Alternator Problem?
Post by captin stu »
Hi im new to the forum and new to 4wding in general.
I recently purchased a 1988 Surf which so far has been awesome, but the alternator crapped out so I was told by a auto sparky anyway.
I replaced it with a supposedly working second hand one but my problem has not been solved.
It seems to be only working when im driving at a decent speed(as indicated by the voltmeter on the dash).
All the dash lights were on constantly before including the charge light, but now they go out after driving for a while??
Long story I know, any help on this matter would be greatly appreciated as I am very confused and out of ideas.
Thanks
Stu
mudlva
Re: Alternator Problem?
Post by mudlva »
try new fan belts as when the belt is old it does not grab the pully properly
Lynx
Post by Lynx »
how well does it start??
Cheers Daniel
captin stu
I have to charge the battery every night then I get a couple of starts out of it.
Im pretty sure now that I have just bought another stuffed alternator. It wasn't even charging when I was driving today.
Perhaps it just worked for a little while then crapped out too.
Lynx
Post by Lynx »
take it back to the sparky and get him/her to check if its charging, or it could be a stuffed battery.
Cheers Daniel
meatc
Post by meatc »
Chuck a meter on it at the alt and then again at the battery. Use a really good earth point. Could be crappy leads/connections between the alt and the battery. Dont keep flatning batterys cause they will die to.
tgaguy1
Post by tgaguy1 »
If you put your location in your user name thingy, someone local to you may be able to pop round and have a look for you.
H2OLOVA
Post by H2OLOVA »
Get the voltage regulator checked
