1KT-TE KZN130 KZN185 Difference?
COMILUX
Post by COMILUX »
Hey
Hope you guys can help me out with a couple of questions i have.
Whats the difference between a 1KZ-TE in a kzn130 and a kzn185 model surf?
I no the kzn185 has longer valves in the head but what about the bottom end?
If i striped a kzn185 block bare and fitted everything from a kzn130 would it be the same as a kzn130? and would i run a small valve head or large valve head?
Thanks
027 337 0579
tallsam66
Re: 1KT-TE KZN130 KZN185 Difference?
Post by tallsam66 »
I know the dipstick is on the other side & the later models run different temp thermostats depending on what vehicle they have come out of.
If its intercooled they have a different top cover....its flat to allow for the intercooler.
COMILUX
Post by COMILUX »
Thanks.
Yea was more interested in internal dfferences as my block turned out to be shot from water sitting in bore for to long and got offered one from a 185 for a good price, found out its had 350ish kms on it tho so droped that idea now.
Managed to pick a decent km tidy cond kzn185 motor complete so will throw that in and do all the usal cooling things etc.
027 337 0579
towtrucker
Post by towtrucker »
the kzn 185 has fly by wire throttle mate and the kzn13o has manual throttle
COMILUX
Post by COMILUX »
just got kzn185 motor to fit in and it has same throttal setup and deisel pump etc at the kzn130.
027 337 0579
towtrucker
really ? im after a kzn185 wiring loom with the fly by wire plugs as my mate has put one of those engines in a double cab hilux.
COMILUX
Post by COMILUX »
Yea its got the same numbers on pump, plugs are the same, tps is the same and has the brackets for the throttal cable and the kick down cable.
Is his a intercooled one? they may be different
027 337 0579
U-BOAT
Post by U-BOAT »
I have been told that you can't interchange heads between KZN130's and 185's. The 185's have a different cooling port arrangement in the head to the block which is why they don't crack heads like the 130's. Also 185 motors had a manual setup for the throttle in 1996 and 1997 as after that they were fly by wire. It is only a matter of changing the fuel pump and inlet manifold off of a manaul setup if the motor is being put into a non fly by wire truck
floatingkiwi
Post by floatingkiwi »
The 185's are only fly by wire after about late 98 to the end of them in 02. All 185's before that (96 onwards) were same manual setup as the 130's.
Matt
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
COMILUX
Post by COMILUX »
Thanks guys.
Only differance that ive found so far thats caused any issue is the dip stick being on the oposite side, when you swap sumps the dip stick hits the sump.
027 337 0579
evolution02
Post by evolution02 »
COMILUX wrote:Thanks guys.
Did you have to do anything special about this or just bend the didstick.
I have a spare kzn185 motor that is low k's that i may get around to replace my higher k kzn130 motor
