Glowplug Problems
nzhunter
Glowplug Problems
Post by nzhunter »
My alternators faulty at the moment and gave me a flat battery last night but when I finally got it crash started then the PRE HEAT (Glowplugs) light didnt go out and im not sure if the glowplugs r doin ther job. Now every time i start it the glowplug light stays on and never turns off and stays on while I drive. Any thoughts? Should I still b drivin it?
DAN
nzhunter
Post by nzhunter »
Oh yeh forgot to say, my trucks an '87 Toyota Hilux Surf, LN61, 2L-T engine. I just diconnected the wire that goes into where the glow plugs are in case they are staying on. Could it be the relay? mmmm :roll:
:? My Surf is having a midlife crisis and its hitting the old pocket a bit hard lol
fearless
Post by fearless »
hey dan hows it goin?
have u checked your glow plugs yet to see if there burnt out?
It may be that your glow plug timer is not turning the glowplugs off after the engine is started causing them to burn out.
so u may need to get an aftermarket glowplug timer fitted
mike
nzhunter
Post by nzhunter »
Cheers Mike,
How do I check if they r burnt out? I think i hav the tool 2 take them out, it came with the truk wen i bought it.
DAN
dctecho
Post by dctecho »
By running with a dead alternator and low battery voltage your relay has probably welded it's contacts together,to test your glow plugs you can measure with a multimeter resistance should be less 1ohm (approx ) The easiest way is to pull them out and connect across a battery and make sure the tip glows red,If it doesn,t glow at all or glows half way up the electrode then bin it.
Not sure were the glow relay is on the hilux,but if there is power on the rail with the ignition key off then id suspect the relay,If the relays coil wires have power all the time(ie the small wires)then the problems with the glow plug timer.
hope this helps
cheers scotty
nzhunter
Post by nzhunter »
Thanks Scotty,
Is there anyone in Christchurch that can give me a hand to check all this stuff out as well as give me a hand to do an alternator swap for couple of dozen? Im still a real novis on diesels as my auto class last year only did petrol engines and I dont have enough tools or knowledge to know what im doin without buggering sumthing up (im more of a practical learner than out of a book) lol.
Any help would be great and much appreaciated,
DAN
021 1411 574
(my 027 phone is not working)
03 332 3365
nzhunter
Post by nzhunter »
Ok its officially now very hard to start i cant get it to start at all today :shock: . Whats a set of glowplugs worth? Steve u got any sets? I just want some that work rather than new ones.
wjw
Post by wjw »
nzhunter wrote:Ok its officially now very hard to start i cant get it to start at all today :shock: . Whats a set of glowplugs worth? Steve u got any sets? I just want some that work rather than new ones.
If its the glow plugs, pour hot water over it... or park it in the sun :)
Who knew Prados could fly?
SupraLux
Complete Bastard
Post by SupraLux »
set of 4 from a good going truck here for 1/2 doz speights... but I really can't help fit em sorry - I'm ballz-to-the-wall finishing Conans truck at the mo and I'm strapped for room and time... I can show you what you need to do tho...
Also have a glow plug relay here if thats crook... better bring an even doz with you :)
Steve
