95 Toyota Landcruiser 80 Series Brake Pedal Sinking
Posted: Fri Sep 03, 2010 7:36 pm
by Sir Plug
Help, my mate has an 80 series Landcruiser that has a sinking brake pedal. We replaced the master cylinder believing that to be the problem but it's still the same. We've clamped all the hoses and it still sinks and there is no fluid loss anywhere. What we have found is that the pedal only sinks when the engine is running. Also, as it sinks, a red warning light comes on the dash (circle with exclamation mark) no other warning lights are on and the ABS works as it should.....any ideas??
Re: 95 Toyota Landcruiser 80 Series Brake Pedal Sinking
Posted: Fri Sep 03, 2010 7:42 pm
by ClassicCruiserSpares
Sounds like its got air in the system somewere and if its got an abs unit they can be a prick to bleed the air out of some times.
Posted: Fri Sep 03, 2010 8:28 pm
by Heath
Vacuum system in the booster. Sounds like a hole in the diaphragm. that's my guess. :?
Posted: Fri Sep 03, 2010 8:33 pm
by Sir Plug
Heath wrote:Vacuum system in the booster. Sounds like a hole in the diaphragm. that's my guess. :?
If it had a hole in the diaphragm, surely the pedal would be harder to press, as if the engine wasn't running?
I'm lost for an answer!
ClassicCruiserSpares, how do we get the air out the ABS system?? Does it need bleeding with the motor running?
Posted: Fri Sep 03, 2010 8:42 pm
by Sadam_Husain
If it only sinks with the engine running it sounds like some sort of vaccum or booster problem, you can discount air in the system or a fluid leak then?
Posted: Fri Sep 03, 2010 9:26 pm
by Landy Rover
Did you replace it with a new one or sec-hand? A pedal that sinks to the floor is fluid passing back from the presure seal and returning to the resivoir. Air in system will give a spongy or springy pedal. A leaking booster will act like its not working with a hard pedal.
If you did fit a sec-hand one its more than likely your problem.
Bear in mind with engine running a lot more force is placed on the master cylinder piston which if it is not in best of health can bleed down.
Posted: Fri Sep 03, 2010 9:54 pm
by Sir Plug
Landy Rover wrote:Did you replace it with a new one or sec-hand? A pedal that sinks to the floor is fluid passing back from the presure seal and returning to the resivoir. Air in system will give a spongy or springy pedal. A leaking booster will act like its not working with a hard pedal.
New cylinder...
Posted: Sat Sep 04, 2010 1:51 pm
by Sir Plug
OK...all sorted. In the end, we had to have the engine running to bleed the brakes. Loads more air came out but now all is good.....must be something to do with the ABS module
Posted: Sat Sep 04, 2010 2:57 pm
Good to hear its all sorted, but yes the vehicle does need to be running to bleed the air from the abs.
