So the disco failed a wof!
Need to fix;
Water in headlight - easy
Weld split in exhaust - easy (some one at work will do for me)
Panhard bushing needs replaced?
Rear driveshaft doughnut needs replaced?
I have obtained the doughnut and bush for panhard but not sure what to do from here.
Are these things fairly straight foward to replace any one have some advice before I get stuck in and give it a go?
Any help is appreciated
Thanks Team
Driveshaft Doughnut
Re: Driveshaft Doughnut
Arrows on outer of donut display which direction the bolts go through the donut, you have a 50% chance of getting it right without looking at those arrows.
I put mine in the wrong holes first time and it only lasted about a month. I now have a driveshaft with universals at both ends instead, much better for sure.
1999 Disco1, 300TDi, Snorkel, ARB Lockers, 9.5k Winch, Custom Bars & Sliders, +5in Lift. Silverstone MT-117
2007 Disco3 TDV6, eDiff, ARB Front Locker, Snorkel, ARB & Kaymar Bars, 12K Winch, Bash plates, Sliders, Llams, Maxxis MT's
