safari on tm
Selling or wanted vehicles.
firestonecruiser
safari on tm
Post by firestonecruiser »
can any of the welly guys give me some info on this truck. considering moving to the darkside after selling the 80. this has been on tm for a while now and wondering why it hasnt been sold. any info would be great. tm listing number (#306665502). would it be a good buy at the price they want.
cheers jono
marmel
Re: safari on tm
Post by marmel »
The first question to ask is if it has been certified.
The tyres and body lift probably need a low level cert.
The other thing to ask is about the HID's. Pretty sure the after market kits are illegal.
Might be fine getting a WOF at the garage the current owner goes to but your local garage might see things differently.
The other problem is with insurance, you can guarantee if you go off the road going around a corner you won't have a chance in hell getting paid out unless the tyres have been certified.
firestonecruiser
Re: safari on tm
have just emailed owner and asked these questions, awaiting a response and a pic of cert plate.
cheers jono
Heath
Re: safari on tm
Post by Heath »
might be just the angle but those rear guards look like they would catch the tyres if you try to stuff one in there. :?
doesnt say turbo but with those tyres you may need one. if it is an aftermarket turbo then that will need cert too.
Re: safari on tm
contour
Re: safari on tm
Post by contour »
you dont need to cert tyres just the rims have been threw it all
marmel
Re: safari on tm
Post by marmel »
contour wrote:you dont need to cert tyres just the rims have been threw it all
You do have to certify any increase where the tyres are more than 5% larger than the factory originals. Pretty much any increase to a 33" or above on a Safari will need a low level cert.
This is taken from LTNZ and provides examples of where you do NOT need a cert:
the tyres:•
– have an outer circumference that is no more than 5% greater than OE, and
– are an appropriate selection for rim width, and
– have tread that does not extend beyond the original or modified body panels or guard extension (see Figure 10-1-1)
So any more than 5% and you do need a cert. Not many garages would pick this up, I know my Safari just got a new WOF running 33's but you if you have an accident and the insurance company looks into it you could be out of pocket.
contour
Re: safari on tm
Post by contour »
i ask that when i got my truck certed. and was told
tyres dont matter just the rims as people change tyres all the time.
On my cert plate its 15x8 rims no tyre sizes put on
Swamped
Re: safari on tm
Post by Swamped »
The cert plates I've seen are for rims only also. However the cert covers the speedo being out of whack from the increased tyre size so you still have to address that issue.
