Keen to do the work myself as I want to learn but not quite sure about a few things.
Things (I think) I know: (or think I should do it)
Smash the caps off
Pipe/tube and pipe clip frpm rear diff up into engine bay with air breather thing/tiny pod filter on top.
Run another from the gearbox and another from the front diff.
Tap both the gearbox and front diff tubes into the rear so its just one main run.
Cable tie the run from the rear diff to the brake lines and follow that to the engine bay.
I need help with:
Anything that is wrong with the above for starters
What type of pipe or tube should I use - cheap bunnings crap or what
what type of pipe/tube joiners to use and where from
any specialist skills/tools I will need?
Where the breather cap is on the gearbox and the front diff
How much slack to leave in the run to compensate for susspension
Any help/knowledge is much appreciated and needed.
