11th/12th sept
11th/12th sept
check out the mods to a mates challanger rear shock mount moved up by 60mm
can flex better with no wheel lift
the new mounting
the shock can now move with axle rotation
turoa
Pyro Junior
Re: 11th/12th sept
Post by turoa »
Not trying to be rude but thats not particularly good flex :?
kbjj
Re: 11th/12th sept
Post by kbjj »
Oh well....a step in the right direction. Factory flex must have been crap. Thats where I started with my mods. SAS next? :D
Jeremy
pradon35s
Re: 11th/12th sept
Post by pradon35s »
working all day and it's bloody hot and the grounds not shaking! FML lol
but heading up worsleys spur tomorrow if anyones keen to come along.
txt 0274699560
adam
Re: 11th/12th sept
its a challanger! they have sod all to start with, any moddest bump they try and roll, so apart from a ball joint flip on the front good as its going to get, not a winch challange truck :shock:
Andrew1706
Re: 11th/12th sept
Post by Andrew1706 »
Working since thursday and maybe, MAYBE get a day off on tuesday.
Over it.
ClassicCruiserSpares
Re: 11th/12th sept
Finished fencing off the back yard today to keep my puppy in, now he has a big play area.
And onto the 40 tomorro.
nstacey
Re: 11th/12th sept
Post by nstacey »
Got the Hilux into the garage today to have a look for a shudder that its had when taking off, 2 of the 3 ujoints in the driveshaft are absolutely stuffed.
Have had a look at taking the old ones out of the yokes but have given up trying to knock them out and no progress in the vice. They don't seem to have the snap rings that my workshop manual mentions.
Where should I take the driveshaft in Welly to get the ujoints replaced?
85 Hilux single cab
02 Grand Vitara
suzookyman
Re: 11th/12th sept
Post by suzookyman »
New Tahs on the Samurai,Hankook RT03s.The Mudzillas were just to scary in the wet on the road.
Al
meece4x4
Re: 11th/12th sept
Post by meece4x4 »
suzookyman wrote:New Tahs on the Samurai,Hankook RT03s.The Mudzillas were just to scary in the wet on the road.
Al
soooo you ready to try them out tomorrow :mrgreen: Hukerenui run is still on .. meeting at the pub @ 9.00am. goo on you know you want too :wink:
lol is it still as high as my Whale on the new tah's ?? :D
lincooln
Re: 11th/12th sept
Post by lincooln »
Rebuilt and extended the carport out the front, now it can cover my Humber Hawk and brothers Mini with working space for the Suzuki (if I push the mini out) Now just to add a door, side and window.
Ordered a heavy duty clutch for the Suzuki and got new alternator and power steering belt. Decided I will sell some of the spares I have for the Suzuki.
Tomorrow will be taking the gearbox out, cutting bonnet ready for snorkel, and prepping and painting the mud wheels. :D
Lubrication Specialist
Lubrication Engineers
Sketchy_Racer
Re: 11th/12th sept
Post by Sketchy_Racer »
Put gear box in, test drive all is well, go to head to missus house to show off how good I am at fixing cars, only to lose 3rd and 4th gear. Dick head.
I think I stuffed up the syncro inserts and they have flipped out leaving me with a 3 speed box.
Tomorrow, do it all again...
SirGerald
Re: 11th/12th sept
Post by SirGerald »
Went down to the square as part of the conservation week.
4 Trucks there on display to pull the punters in for a look to see what else was going on
Was also a good test for the new tow wagon (Ford 150 for a big ass v8).
Shame I have to take it back on Monday :( Has been interesting to drive a left hand drive vehicle, especially through the McDonalds drive through. Very tempting to take it out for a 4wd but think I had better not temp fate.
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
suzookyman
Re: 11th/12th sept
Nah, working on getting the winch going,have fun :D oh its a we bit higher :(
Al
fj40
Re: 11th/12th sept
Post by fj40 »
well chopped the back of the zook put air on the back just gotta find somewere to mount the spear wheel 32'' are big when ya wanna put one on the back of a zook
its not how big the 4x4 is its how angry the diver is
marmel
Re: 11th/12th sept
Post by marmel »
Installed boost & EGT gauge on dash in preparation for my turbo install.
Finished off my spotlight wiring including wiring to an internal switch on dash and to high beam, both via 30amp relay. Wires will run through one of the tubes of my bullbar to keep things tidy.
Started grinding the welds on my bullbar to prepare for paint. Managed to stuff my back pulling it out of the back of my Safari (must be about 60kg).
monstr
Re: 11th/12th sept
Post by monstr »
Took the truck up to Woodhill,last run before the Manukau winch challenge, after loading it up we could smell clutch ? found rear crank seal is leaking ,bugger all but enough to cause later problems ,So next weekend looks like the gearbox comes out "bugger" any Nissan owner will know what thats like useing trolley jacks :cry: Still better to find it now than in a couple of weeks
flyingbrick
Re: 11th/12th sept
Post by flyingbrick »
I gave my dog a bath. smells nice now.
Fakey
Re: 11th/12th sept
Post by Fakey »
Had a piece of steel in my eye since friday (got it out this morning) so been in a shit mood all weekend :evil:
To make things worse I pulled out my air locker out, only to find the diff pinnion teeth cracked an broken :evil:
On the plus side it is an old Roberts/early arb locker. Bad thing about the locker centre is that the spider gears had all picked up on the pinion shafts :x :x :lol: wonder if I can still get parts for it :lol:
Didn't barbie drive a jeep??
Re: 11th/12th sept
Looks like Cindy has had some upgrades :D
lincooln
Re: 11th/12th sept
Post by lincooln »
painted the mud wheels black, removed radiator and cleaned about 2kg of sand out of it, shouldnt need the heater on i traffic now :D
also drained the gearbox and transfer case oil, removed starter motor, ready for the gearbox to come out. Picking up new clutch kit tomorrow, and ordering the gaskets I need.
sig
Jeep Jeep
Re: 11th/12th sept
Post by sig »
had another play with sadams motor today .had a couple of broken exhaust studs to get out .two came out easy but the third is being a bitch .Drilled it out with a cobalt drill first then broke the easyout in it feck feck feckin feck.then learnt a new trick .Being alloy heads if you are quick you can gas cut the broken easiout out without melting the head .Then broke the cobalt drill in there feck feck feckin feckin feck .now i need some more cobalt drills .still some of the broken stud in there as the drill wandered off centre .might be a case of over drill it and helicoil it now.had to have a couple of tuis to calm down .Worked a treat now i,m calm and ready for a few more.Pity i have work tomorrow. The other acheivement for the weekend was as my van is in the panelbeaters for a month they have given me a loan van .A 1.8 diesel ford escort .Bloody thing struggles to get up my drive in 2nd gear ( my drive is not very steep).Trying to fit a hiace vans worth of gear into an escort van does not work . insurance man says repairs will be a couple of weeks panelbeater says at least three .needs a new rear tailgate ,front passenger door,rear left quarter chop ,new left radiator,front left pillar repair and a whole new roof.The bugger is some of the parts are ex japan .Think they may take more than a couple of weeks Triple feck.
Fakey
Re: 11th/12th sept
Post by Fakey »
What happened to your van Sig? :o
y60 safari driver
Re: 11th/12th sept
Post by y60 safari driver »
cleaned up round the house sat then golf and a couple of beers with the boys sunday :)
sig
Jeep Jeep
Re: 11th/12th sept
Post by sig »
Fakey wrote:What happened to your van Sig? :o
have a look at the daytime post page 361 :(
Re: 11th/12th sept
ring Ken Sig
fit lots more in a truck, may even have slightly more power, just :shock:
suzukisport
Re: 11th/12th sept
Post by suzukisport »
Spent the weekend in Wellington, picked up the new trailer, missed out on a good 4wd run :evil: At least now im not going to break it before Manukau WC :lol:
wopass
Re: 11th/12th sept
Post by wopass »
did a bit of work on the 40... :roll:
meatc
Re: 11th/12th sept
Post by meatc »
Spent some tne in the shed and got most of the dash rewire/tidy up done.
Pulled starter motor, which was another victim of rotorua, brushes were jamed solid and every spare space was full of mud. Cleaned and put back together reinstalled only to find i stuck the lever from the soliniod in backwards :evil: back and and back in again.
Nearly ready for Manukau now, well thats if then engine copes with the extra puff. :lol:
wopass
Re: 11th/12th sept
Post by wopass »
meatc wrote:Nearly ready for Manukau now, well thats if then engine copes with the extra puff. :lol:
im in the same boat except im still pulling things apart :lol:
hope i can get it back together before race day :?
