Been playing with my boost settings and finally Fuel. (after all the exhaust and intercooler stuff)
Have put in an aftermarket boost controller and set it up to boost to just under 13 psi. Just before the cut out activates.
(Real time trials and is nice and quick
Now I am tweaking the fuel via the Fuel Spill Valve.
Taken it up 1/2 a turn.
Now it gives a little puff of black when you give it a quick rev, never used to do that.
Now heres the kicker... Its now running cooler on the EGTS when giving it the welly...and on boost.
Cooler when doing 100k's on the motorway.
Dropped a good 50C....plus
I thought it would get hotter???
Going to turn in another 1/4 for the run home later tonight.
But what gives with the temps going down.??
Will a diesel which is way to lean run hotter?? Maybe inefficent.
I thought they did the opposite as a petrol.
Your thoughts Gentlemen and Ladies
Calvin
