fj40 fj45 gearbox
liftedfj
fj40 fj45 gearbox
Post by liftedfj »
gday i have fj40 and was wondering if a 45 gear box would fit in the same as a 40 box????? its easyer 4 me 2 get a 45 box
krawlr
Post by krawlr »
yep as long as its the f serries bell housing and the 3 and 4spd usually have different bolt patterns on the drive shaft flanges too ....
good luck with the swap
liftedfj
Post by liftedfj »
so shud just fit right in ??
krawlr
Post by krawlr »
yep both petrol arnt they?
go to it dude :wink:
the only difference to watch out for is between the petrol and diesel gearboxes, the diesel boxes have a long fine spline input shaft and the petrol have a short coarse spline input shaft... dont get the wrong one!
If you have a later 40 series your gearbox will have a crossmember and mount as opossed to the earlier ones that hung straight off the bell housing without any mounts.
MNC
Post by MNC »
Posted: Tue May 23, 2006 7:00 pm
[quote][/quote]
I`ve just replaced the clutch in my FJ40 and I can let you the gear box weights a sh*tload. It took about 1hr to get out :D and 3 days to get back in :x Helpd to have the right tools for the job of course. Good Luck
krawlr
Post by krawlr »
well there both fjs not bjs arnt they so they will be both be petrol boxes so spline differences is no issue :shock:
so throw em im mate.....
liftedfj
Post by liftedfj »
cheers will do going ta borrow my m8s works work shop for it so should make life a little easyer 8)
