Just read another (old 4wd mag) review by a major magazine and the review results are as weak as piss. The tyre that stood out isnt one of their big advertisers so the conclusion is that there isnt a best tyre out there and it depends on you needs.
My pick from their results was the Maxxis bighorn (or was it a Buckshot?
If I read between the lines and compare the comments about wear and tear I would avoid some of the big players...
Maybe we need the AA or Consumer to do some tests that can be replicated for new entrants and the results are then comparable to previous tests. Seems each time Aus4wd do a test its different.
I'll be buying a cheaper MT if the performance difference between them comes down to the name on the side and thats about it. I was amused to see the Maxxis tyre beat the BFG KM2 in the mud challenge though.
