It would seem to be a lot easier to install the water feed/return using the heater hoses they have tapped into.
Any reason why others tap into the thermostat housing and side of the block?
DieselBoy wrote:Because tapping into the thermostat housing is way less bodgy than cutting and "T"ing into your heater hoses.
That would work ok, but not how I would be doing it![]()
flyingbrick wrote:fark. post last night didnt go through.
There is nothing wrong with that setup. If you get some kinda airlock with that setup you'd get the same airlock with any other setup.... unless you make your turbo the lowest part of your cooling system hahahaha.
Whats is boogie about it? It will work, its tidy, its easy etc etc etc.
why go through the trauma of drilling and tapping block just for a water line
flyingbrick wrote:it does not matter which way the water flows through- but make it as easy as possible for any air to get out of the core- eg water flowing in from the bottom and out through the top.
darinz wrote:Why cut a hose when the fitting in the block is a case of undoing a plug and chucking the hose in there with the right fitting?
And why cut a hose when you can just take out the fitting into the thermostat houseing a fit one with a T for the return?
Seems to me cutting the hoses is quite OK but the other way is really easy and tidier.
