Courier 2.5TD Running temperature.
Posted: Thu Sep 23, 2010 9:48 pm
by Proctor
Hey all, after installing an after market water temperature gauge tonight I went for a quick drive down down the motorway, I found that my running temperature at 100km/h Was around the 105 degrees Celsius mark.
As the faulty stock gauge had no kind of upper and lower limit indications I have no idea what the normal running temperature should be, and a google search has been no help.
Can anyone provide me with some insight?
Re: Courier 2.5TD Running temperature.
Posted: Thu Sep 23, 2010 9:51 pm
by meatc
Not sure what the temp is supposed to be but do know that the cooling systems are known for clogging up. If it has a fes kays on it (like over 70,000) it will be well over due for a radiator rodding, not just a flush but top tank off and each tube rodded.
Mate/sponser (Whangarei Radiators) is at me to do mine and the truck only has 45000k on it. He wants it before it pokes the radiator and then the engine.
Posted: Thu Sep 23, 2010 9:54 pm
by sibainmud
Hi,
I run a bounty on the road, the thermostat is fully open at 86 deg C. If you going heaps over that, then somethings up :roll:
If it is spewing out water or you are having to add it then the head WILL be cracked (they all do it, apparently).
Bolted a chinese one on for about $1200 incl all new exhaust valves and head studs. 105 is too high.
Posted: Thu Sep 23, 2010 9:55 pm
by Heath
New thermostat and flush time. get the rad done as well (cheaper then a new donk) and change the hoses too (keep the old ones for spares). Mine was running hot and then the head went (petrol 2.2 courier), cost me over a grand.
I would imagine it should be around 87-95 deg C. My prado runs at 86 deg C most of the time.
Posted: Thu Sep 23, 2010 10:29 pm
by sibainmud
Come to think of it, here's some pics.
315,000k's 2001 :shock: :shock:
You can see the water stain running down the bore, was giving me grief for a couple of years :?
Happy "head hunting"
Posted: Thu Sep 23, 2010 10:51 pm
by Proctor
Cheers for the quick responses guys, I will definitely be taking her in on Monday for a new thermo, might go to the local radiator specialists for a proper flush and service, I would preferably like to avoid a new head 8)
