so what are the plans for the long weekend QBirthday 2006
any expeditions or modifications you are planning to do
me i'm going to cruise down to my parents place and put the turbo on my wagon hopefully give it a little more power which it desperately needs i might take my muddies with me incase i have enough time to go play on monday
i would have done it earlier but i figure if i allow 3 days to make all the little brackets and things it is better not so much stress so things should get done properly especially as i use it as my runabout
Mums 60th friday night so that will mean saturday is a right-off
Get a 307 chev engine running ready for sale - unless someone wants to make a reasonable offer and repower their toy?? (was running in a 1969 G60 Nissan Patrol , so still has 3 speed manual and transfer box with it
Make sure Lil Pig is running for a club comp the following weekend......
weekend work
I'm going to start on changing my timing belt, waterpump, idlers and crank seal, then might start on putting the locker into my rear diff with new bearings, seals bearings, shoes .......... do you see the picture forming?
u-Boat
u-Boat
putting some trellis up in the front yard on saturday then finishing off my new front bumper, sunday will be spent putting new wheel bearings/seals/swivel hub seals/bearing in the front of the surf and monday ill finish off passenger seat rail and put front window in...
hmmm lots of front in that.....
Hitting the road tomorrow just after midday for a quiet long weekend in and around Turangi. No 4 wheeling.
But if any of the Wellington guys haven't had enough playing yet over this long weekend and are keen on another trip the following weekend, I'd be keen as mustard as well.
Got a set of brand new muddies sitting in the garage waiting to be tried out
