Landcruiser failed a WOF as apparently rubber flares need to be certified!!
So, just about to go through the process of getting the vehicle certified.
Currently has 33" tyres fitted, but was thinking if I can find some old 35's I could then get it certified for both 33" and 35" at the same time. Would save having to get it recertified when i eventually go for some decent 35's.
Just wondering if anyone in the queenstown/southland area might have some old 35's and rims (either 35/12.5/15 or 315/75/16) that they are wanting to sell..?
Wanted: Old 35" tyres and rims to suit 80 series
Re: Wanted: Old 35" tyres and rims to suit 80 series
if your on to it borrow some 35s on beadlocked rims add them to the list for later addition.....
WARNING:
it will have to be certed on either a 33 or 35 they wont do both as the to different sizes will drive different from each other.your truck may pull up fine on the likes of the brake test but when it is on 35's it may fail etc so i would be certing on the 35's so you know it says its good for bigger tyres...in saying that cert plates dont have the tyre size stamped on it only rim size...............
