lsd for mu
For all Isuzu related topics
fatcat
lsd for mu
Post by fatcat »
hi i need help i have 94 mu it doesnt have lsd would i benefit by putting one in and if so what would i use as have limited budget any help would be great thanks
mud_slinger
Re: lsd for mu
Post by mud_slinger »
if you can find a lsd definately chuck one in the rear, makes a huge improvement. i have one in the rear and works really well.
Price wise look on trade me. where bouts are you located?
it would be a 3.1 engine?
needs more curry
0272593533
fatcat
Re: lsd for mu
Post by fatcat »
live in palmy north.have been told to use bighorn dif head but the gearing is 4.1 and mine is 4.3 so i have been told. will the point 2 make a difference .and yes its a 3.1ltr
mud_slinger
Re: lsd for mu
you dont want to change your gearing just look round trade me or local wreckers for one they are around, mine has one and also got one sitting in garage awaiting its shimming so can get super tight.
needs more curry
0272593533
octanepwr
Re: lsd for mu
Post by octanepwr »
You will definitely benefit. I just put a LSD from a 91 rodeo in the back of my 87 bighorn. Even with rubbish tyres on huge difference in traction.
You need to stick with the same ratio as your front, so unless you want to change the front one aswell you better find one with the same ratio.
Try trademe, diffs from the 3.1D bighorns probably fit also, someone should be able to tell you if that is the case.
Drurban
Re: lsd for mu
Post by Drurban »
I have an LSD in the rear and I think it is a great benefit, I would not go in the places I have been with out one, but I will be soon putting in a Air locker in the back.
Ruben
Return to “Isuzu”
