Now its in for a big over haul
So heres the plan so far: V8, 5speed, Wide coiled diffs, FRP top cut down to single cab, EXO cage an maybe internal aswell, PTO winch moved back for better approach angle.
Heres the original thread I started when I got the truckhttp://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=21408&hilit=+bj74+pos
When I got it
Did a few things to it, made a snorkel, fitted some 33"s, then a 2" lift kit, sliders an 35"s
FRP chop
Pulled the leaves, an front diff out an started mounting the patrol front diff an coil set up, using a empty housing
Still working on the rear mounts
Sat a 35" about where itll sit with hubs on, tyre atleast 100mm furthur out than it used to
10.10.10
Had a busy weekend empty housing out, complete diff in, 99% of welding done on front end
control arm mount 2.0
Panhard rod, (80 series with 3/4" hiem for adjustment.)
Rear patrol springs up front, Fronts were too short an fell out. Looking for some 80 rear springs thatll fit better
Went for a quick road test, oops no brakes
Wheel base is currently 105"looking to push the rear axle back around another 3" so itll sit more like in this pic
Also hoping to get final ride height up about another 2" from where it is but thatll wait till the engine swap an winch is done.
Rear diffs out now too, ready for some 80 series goodness
Ill edit the first post as work progresses, aiming to have it back on the road by end of november
