bigger starter motor on 2l?....
Posted: Tue Oct 05, 2010 9:32 pm
stripping engines out of our two old '87 4wd vans to do engine swap. identical vans. But one has a much much larger starter motor. it must be 50mm longer and motor is bigger in diameter. Even the main feed cable from battery mounts two solenoid with a 17mm nut
any ideas what it might be off? castings are all the same shapes and it fits the same way.
