Installing airlocker.
brakes-shocks-lockers-etc
ashleygt
Post by ashleygt »
Im going to put a airlocker in the back of the hilux, will do the seals but would you bother doing the bearings? Its only got 250k on it. Cheers
Fakey
Re: Installing airlocker.
Post by Fakey »
Do them if its your daily, or they are showing signs of wear. Other than that id leave them if they look ok an its your play/weekend truck
Didn't barbie drive a jeep??
mroffroader
Post by mroffroader »
You have to replace them? I wouldn't press bearings off and then back on to the locker as the chance of damaging them is pretty high, even if the damage cant be seen to the naked eye, why would you risk putting a whole lot of bearing material through your brand new locker and diff?? Spend the couple of extra bucks dude....worth it in the long run :wink:
