Will a front diff fit the rear in suzuki sj413?
I have a spare front diff for a sj413 will it fit in the rear? Or are the axles different size?
- Rotazuk
Re: Will a front diff fit the rear in suzuki sj413?
Axles different size . Can swap out the side gears but may be easier to get a rear diff .
Chris
Chris
- You Get That
You need to reword your question. Are you talking about
Putting a front diff head in the rear houseing?
Putting the inner axles from a front into a rear
Or putting the whole front axle under the rear to make a rear steer setup
Addicted to suzukis....
Sory mate, Rotazuk got it right was thinking of puting front diff head in the rear housing, had a feeling front axles were different to the rear. chees for help guys
