Body lift coming up . . .
Posted: Sun Oct 10, 2010 11:03 pm
by kernels
Hi guys,
I drove up onto some stacked ramps over the weekend and found that I can get the rear tyre to rub on the guard :(
So, it looks like I will have to go ahead and do the body lift.
Is the 2" set for sale on TM for around $275 the best way to go ?
What did you guys do ? Anyone make up their own blocks ?
Thanks for any advice as usual!
Hein B
Re: Body lift coming up . . .
Posted: Mon Oct 11, 2010 2:17 pm
by kernels
Got one of the $275 kits of TM, hopefully it's all as easy as advertised!
Posted: Mon Oct 11, 2010 2:52 pm
by aLUX
Ive heard that 2" means you need a cert.
Best to make up your own to about 47-48mm.
Also it would be cheaper to make your own.
Posted: Mon Oct 11, 2010 2:56 pm
by Lynx
im personally not a fan of body lifts, the extra stress on the mounts can lead to an accident or damage them.
Have a read
http://www.offroadexpress.co.nz/Forums/ ... t+accident
Have you considered a virtual lift instead, ie, chopping guards?
Cheers Daniel
Posted: Mon Oct 11, 2010 3:05 pm
by F.Y.C 4wd
hay Hein
iv got a calmini 3 inch body lift in mine and the guy at vtnz said it would need cert but he said if it was 50mm/2 inch it would be fine so i have just brought the one off trade me for $250 that is the one made from the black blocks and plan to swap them over tomorow if its here
so i can let you know what its like
cheers aston
Posted: Mon Oct 11, 2010 4:07 pm
by kernels
Hey guys,
Thanks for the feedback, yes, generally I would not be a fan of a body lift, but in this case it is really the only sensible way for my wide offset tyres to clear without some serious rear guard cutting.
As far as I've read on the LVV certification guides any body lift requires a cert, but that is not a big deal since I was planning to have my brake modifications, new sized wheels and track width increase certed anyway. These are all things that should technically trigger certification.
FYC - Yes I also bought one from the same guy today, please post some pics and any issues you encounter while fitting the kit, would be awesome to have a heads-up about what I'm in for. I will probably fit mine over the coming weekend.
Thanks for all the advice guys.
Hein
Posted: Mon Oct 11, 2010 8:28 pm
by Heath
Check the radiator isnt attached to the body (not sure if they are... :? ) when you lift or the fan will catch and break on the shroud.
Posted: Mon Oct 11, 2010 9:26 pm
by kernels
Heath wrote:Check the radiator isnt attached to the body (not sure if they are... :? ) when you lift or the fan will catch and break on the shroud.
Thanks Heath, good advice as usual. I will double check that before I begin. Cheers Hein
Posted: Tue Oct 12, 2010 6:40 pm
by F.Y.C 4wd
hay kernels
got the lift in today after school it fit well and came with good instructions just make sure you keep cheaking all cables and hoses when you jack the body up
mind you though mine already had the 3 inch one in it so might not be so easy good luck tho :D
Posted: Tue Oct 12, 2010 7:00 pm
by Heath
Best advice is to do the unthinkable and read the instructions, then climb underneath and have a look at the underside and then read them again a few times making sure you note all the points in the instructions.
Yeah I know how "unbloke like" reading instructions, but it might save headaches later on (and maybe some cash).
Oh do it on a dead flat surface and take your time. :mrgreen:
Posted: Tue Oct 12, 2010 7:59 pm
by lincooln
and maybe post up the instructions as I got my blocks but no instructions. Mine is only 25mm so its not as big a job as some. :D
Posted: Wed Oct 13, 2010 8:49 am
by kernels
Hey guys, got the blocks yesterday, looks like a really nice tidy kit. Will be fitting them this weekend (hopefully) and will post plenty of pics and details for those looking at doing this soon.
Hein
Posted: Wed Oct 13, 2010 8:50 am
by kernels
F.Y.C 4wd wrote:hay kernels
Hi FYC, glad to hear it all went well! Will do as you recommend - take it easy and keep checking all cables and hoses!
