1uz to a434 prado g/box HHHEEEEELLLLLPPPPPPPPPPPP
Hey, mates 1kz just crapped out on him and were thinking on putting in a 1uz, anyone done this before? how do you get the computer to talk with the engine and g/box?
Re: 1uz to a434 prado g/box HHHEEEEELLLLLPPPPPPPPPPPP
do a search man, done and dusted 100 times
and check out marks 4x4 adapters
Cheers Daniel
Cheers Daniel
it may have a stand alone ecu for trans otherwise just set it up for manual shifting
I have done this in my truck, its quite easy, and the easiest way is to my make a small computer for it and set it up for manual shifting as you can change gear when YOU want to and it does what YOU want it to do. there are many different types of computers that people have developed that are in use in the same application, things like shift speed etc. A common computer can only consist of a couple of one way diodes and couple of relays. It has been covered several times on here, and also www.lextreme.com so give these places a look.
