Removeing A/C in truck
- You Get That
Pulled the air con out from my sj413 today and was wondering what to do with the two pipes going to the core?
I was thinking just to join both together?
Addicted to suzukis....
Re: Removeing A/C in truck
in my surf, i just blocked the ends up with some silicone.
Cheers Daniel
Cheers Daniel
- You Get That
Sweet i wll just make some bung holes or somthing
cheers.
cheers.
- flyingbrick
why does it matter? I don't get it
- You Get That
Because there are 2 hoses leaking coolant in the engine bay that used to go to the A/C that i want to fix
- Nivapulledout
So it is the heater core hoses then.
If it was the heater hoses from the motor then loop them back together to complete the coolant circuit for your engine side.
The cabin side can be left open....
Calvin
Calvin
- flyingbrick
You Get That wrote:Because there are 2 hoses leaking coolant in the engine bay that used to go to the A/C that i want to fix![]()
A/C generally refers to the cooler part of the system... which wont leak anything once de-gassed.
If its the heater core then do as kbushnz said. Its pressurised so chances are will blow silicone out eventually
Also you said you are going to make some
bung holes
I'm interested to see this? are they holes that require bung-ing (you already have two of those
bung·hole (bnghl)
n.
1. The hole in a cask, keg, or barrel through which liquid is poured in or drained out.
2. Vulgar Slang The anus.
- You Get That
So im going to make a connector between the 2 hoses now.
You Get That wrote::lol:Riteo and i did say core in my first post
I saw that and thought you meant the air con cooling pipes too.
On my old vitara (Meece's "Mistress" now) I made up a piece of hose to join the two heater pipes together (closed the loop), everything else got ripped out.
- You Get That
Heath wrote:If you have the heater unplugged why not just remove the heater shite altogether while you are at it too (or is that what you meant you had done?
Yea thats what i did heaps of room now
- You Get That
Decided Im going to hook the hoses up to the water cooling holes on my turbo
Perfect
You Get That wrote:Decided Im going to hook the hoses up to the water cooling holes on my turbo![]()
Perfect
Nice bit of lateral thinking there bud.
