Nothing ever seems to be easy. I had the front driver's side wheel removed today to fit the new rubber flares. Anyway, decided I would quickly double check the diff ratio to make sure it's 4.6 since I intend to fit some 5.125 diffs to fix the speedo and engine with the new larger diameter tyres.
Anyway, I locked in both hubs and turned the drive shaft by hand, now, unfortunately at this stage I realized that the wheel (that was in the air) wasn't turning! Took the locking hub off and confirmed that it was working fine, removed the outer cv boot and found this:
http://www.andante.co.nz/projects/vitara/pics/cv/cv_1_large.jpg
http://www.andante.co.nz/projects/vitara/pics/cv/cv_2_large.jpg
So, it looks like the spline going into the cv pulled out when I was fitting the cv into the new wheel hubs
So, what's the easiest way to remove the cv to see if it's salvageable ? Do I have to remove the wheel hub again ??
Any advice greatly appreciated as usual!
Thanks
Hein
