How do i tell if i have an LSD?
Shortpaj
Post by Shortpaj »
Been trying to tell if i have an LSD or not without having to pull it out. my paj is a 1993, 3.5 v6 swb
is there any way of being able to tell?
Whats the part # for the lsd diff? maybe i can compare?
Thanks
Chris
badnuz
Re: How do i tell if i have an LSD?
Post by badnuz »
put the rear on axle stands and spin one wheel.. if open the opisite side will go in reverse if LSD it should spin in the same direction :)
Shortpaj
Post by Shortpaj »
Well i knew it had to be easy :D lol
Thanks for that will check tonight haha
NJV6
Post by NJV6 »
Look on the filler bung for the rear diff. It will say LSD, and I'd say yours will be LSD.
pjb
Post by pjb »
badnuz wrote:put the rear on axle stands and spin one wheel.. if open the opisite side will go in reverse if LSD it should spin in the same direction :)
Gotta be in Neutral for this to work ;)
94 Pajero SWB, 3.5 V6
Return to “Mitsubishi”
