eletrical issue
Posted: Wed May 31, 2006 12:41 am
by MATT4U
My tail and park lights lights stopped working and I couldn't find anything to stop them working so I connected them up to my number plate light, the problem now is unless its still connected to teh old circuit teh break lights dont work and if i di that the dash ights come on whenever I break. What I want to know is where s teh switch that turns the break lights on?
Posted: Wed May 31, 2006 7:16 am
by krawlr
should be on youre brake pedal look under the dash ...............
Posted: Wed May 31, 2006 10:46 am
by Steve_t647
Are you sure you dont have a dodgy earth on the tail lights, for all of them to stop it sounds like a earth problem.
Posted: Wed May 31, 2006 11:13 am
by SupraLux
Or the tail-light fuse in the kick-panel fusebox...
Posted: Wed May 31, 2006 2:35 pm
by MATT4U
all fuses are ok
Posted: Wed May 31, 2006 2:49 pm
by oldblue
On L/C there is a plug in the tail-light loom, just inside of the rear guard panel, where the tail-light loom plugs into the main loom, sometimes they need to be checked for good contact. May be the same on other Toyota's
Posted: Thu Jun 01, 2006 11:22 pm
by sparx
if your dash lights come on when you brake it means the circuit is good all the way from the dash to the back, but put it back the way it was and get a meter then check from the fuse to chassis with brake pedal depressed, if you get voltage then go pull the interior panels off in the back and check for voltage at the plugs, if theres nothing follow the cables back and youll find your fault.
But I rekon youve got nothing at the fuse.
