Soft Wheel Nuts
downunderxj
Soft Wheel Nuts
Post by downunderxj »
In checking brakes etc at the weekend I was taking each wheel off one by one and going over everything in behind.
The final wheel had one wheel nut that wasn't going to budge, so a bit more pressure and I now have a very pretzeled looking wheel nut, they are not steel but lightweight alloy and occassionally get very tight.
So now I have to work out some way of getting a shapeless wheel nut off the stud :cry:
Any ideas :?:
I do have an air chisel that came with the air compressor I acquired earlier in the year. Do I use that to split the nut??
Thanks for any sensible suggestions.
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
Re: Soft Wheel Nuts
raid somebodys socket set
get a socket that wont quite fit over nut
bash it on and very slowly undo nut
make sure its somebody else socket set though
coz it will be fukt afterwards
vitara888
Re: Soft Wheel Nuts
Post by vitara888 »
The wheel nuts have a sheet metal cover over them to cover the end of the thread, hopefully you have just spun that around. See if you can chisel it off and then should still be a nut underneath.
sig
Jeep Jeep
Re: Soft Wheel Nuts
Post by sig »
i had a similar problem and have bought a nice socket for removing buggered nuts .It looks like an impact socket but has a reverse cut thread on the inside .It might work for you .Come round and grab it
Heath
Re: Soft Wheel Nuts
Post by Heath »
A bit of heat will help too (not much just hot to the touch not glowing)
downunderxj
Re: Soft Wheel Nuts
Success today :D , the special socket that I borrowed off Sig managed to quite easily remove the soft cover over the steel nut that Vitara888 mentioned. Then the right size socket, a long breaker bar, and a bit of elbow grease got the nut moving. Had to repeat the same process on another one too. Time for a new set of wheel nuts.
I had tried Skid's trick with an old socket, but chose one that was too cheap and split it up the side. :evil:
Thanks to the suggestions, the ideas and the socket - I will drop that back off in the next day or two Sig
Ian
Return to “Jeep”
