TD42 starter problem
For all Nissan related topics
3VILC
Post by 3VILC »
Hey guys,
Got an intermittant starting problem. The solenoid clicks and all lights go dim and volt gauge drops but starter doesnt turn at all, click the key over several times and eventually it starts without a struggle that would indicate low batteries. At first i thought the solenoid might be buggered, but on my last outting offroad i discovered that the winch is doing the same thing. Strange. Any ideas? maybe a dodgy battery cable somewhere? Have replaced all the terminals and cleaned the earth lugs.
Swamped
Re: TD42 starter problem
Post by Swamped »
Mine does that too but could never diagnose it. I changed batteries a little while ago and hasn't happened since so maybe i fixed it unknowingly.
albundy
Rolly Polly
Post by albundy »
If its afactory electric it will be going thru the starter soleniod, found this out after wiring up an aftermarket winch. When my starter was doing this I just gave it a good clean as it was covered in 20years of oil from dripping filters at oil change time and mud. Took this all away and no problems since.
Al.
3VILC
Post by 3VILC »
Thought it might just need a good clean out. Is aftermarket electric winch, maybe also just needs a good clean out. Im guessing by the looks of the layout the solenoid infront of the high side battery is the main starter relay or an old factory winch solenoid, think it had a factory winch but my aftermarket is wired directly to the battery
meece4x4
Post by meece4x4 »
yup mine does that about once or twice a month .. only started doing it after a bath at Woodhill so im picking its just crud/corrosion on the armature on the to do list :lol:
bobrocket
Post by bobrocket »
+ 1
Mine does the same thing every now and then, it's on the list but might of lost a few slots now that I know its a common problem :D
will i am
Post by will i am »
done a few river crossing in the last couple off weeks.
my starter was on the way out before then tho
working slowly
terrano wouldnt start after driving to work this morning.
pulled it apart today and full off mud.
reason for not starting was/is brushes are gone.
prity cheap to replace. about 25plus gst for brushes then labour
another d21 terrano
ex lancer build
