Bit of an awkward fit to get the Moreys bottle into the filler hole so I extended it with a short piece of fuel pipe, thinking to myself, best be careful not to drop that into the gearbox.....
So yeah, I dropped it into the gearbox. Took the drain bung back out but I can't feel the pipe in there or through the filler hole.
Once you've stopped laughing some advice, bright ideas would be awesome. At this stage the only way out I can see is to drop off the transfer case which I've not done before and the only advice in the Gregory's manual is for separating the two once you've removed gearbox and transfer from the truck.
So umm, help!!
