Adjustable Panhard Questions...
Posted: Mon Nov 01, 2010 10:19 pm
by Jerry
This turned up today :D
I'm assuming the bigger the lift the longer it needs to be?, Is there any common adjustments eg for a 2" lift it needs to be x longer?
Re: Adjustable Panhard Questions...
Posted: Mon Nov 01, 2010 10:58 pm
by kbjj
eyeometer works for me :D
Posted: Tue Nov 02, 2010 2:36 am
by Nivapulledout
a few simple measurements and you should get it spot on. load up your wagon to what it normally is when cruising around and then measure the distance that your wheels stick out (or stick in) from your arches, keep adjusting till they are even.
Posted: Tue Nov 02, 2010 6:21 am
by tallsam66
Where did you get it from & how much?
...ive been looking for 1 of those for ages for my surf .... seen similar on an aussie web site but they wanted silly money
Posted: Tue Nov 02, 2010 3:40 pm
by coxsy
its heavy hard steel, custom threaded, ticketed welded and garenteed , yes all that costs no matter how many you make
Posted: Tue Nov 02, 2010 5:10 pm
by Jerry
Found it on TM cheap :D
Could get JAFA to have a look at it and see what its costs to copy it if there is interest :wink:
Posted: Tue Nov 02, 2010 5:21 pm
by tallsam66
Im interseted .... even got a spare panhard rod to use as a template if required.
Posted: Tue Nov 02, 2010 8:02 pm
by smurf182
Or you could just drop the mount at the chassis end, probably easier to fab and maintains correct geometry.
Posted: Thu Nov 04, 2010 8:13 am
by Jungle
I've given up on adjustable rods. Once I have the lift sorted I make the rods up to suit. Even with a five inch lift on an 80 series cruiser, the panard rod only increases by about 10mm.
How many times are you going to change the length of the panard rod???
Jungle
Posted: Thu Nov 04, 2010 11:24 am
by rokhound
I'm with Jungle, once you have your ride height sorted, how often do you alter it?
My POS has 10" of suspension lift over std and I fabbed the mounts to suit a standard 80 series panhard rod.
Posted: Thu Nov 04, 2010 2:17 pm
by Jafa
I agree, adjustability is a waste of time, just make or use, a panhard that is as long and as flat as possible at ride height, and make the mounts to suit....
Posted: Thu Nov 04, 2010 10:28 pm
by lilpigzuk
Posted: Thu Nov 04, 2010 10:33 pm
by lilpigzuk
Posted: Thu Nov 04, 2010 10:39 pm
by lilpigzuk
Posted: Thu Nov 04, 2010 10:52 pm
by lilpigzuk
:lol:
Posted: Thu Nov 04, 2010 11:46 pm
by kbjj
What you've got will work, but custom length ones are cheaper to make, lighter and arguably (is that a word) stronger. I have a bush one end like yours and a heim on the other. Just replaced heim after only 8 months service. Heim looks ok but has a sloppy ball :roll: , looks like the teflon lining has dissappeared. I might try and put a rubber sleeve on each side of heim to keep teflon lining in and crap out.
Well... its a simalar subject. :D
