i used to own a 89 bighorn and it died a long death because of worn rings causing blow by.
im curently looking at buying a 93 bighorn and it looks tidy.
i couldnt find the breather to test if it had any presure in the crank case like my old one so i popped the dip stick out and there was a bit of gas blowing out there.
my question is, is this at all normal and ok? obviously there has to be some pressurisation but how much if any?
how much blow by is bad?
Re: how much blow by is bad?
why not get a compression and leak down test done.
- mud_slinger
if it has lots of blue fumes coming out dipstick tube, its toast. but make sure you do the dipstick test when engine is up to temp
needs more curry
0272593533
0272593533
If it's diesel the other thing to keep in mind is that the motors are known to be heavy breathers, even low milage and in good condition.
There are kits available to help with the problem.
Catch can breather style kits?
- mud_slinger
you can get a custom catch can specific to the isuzu from a mechanics in chch called AMMA MOTORS, they are specially designed for the isuzu and for the blow by, also the bonus is the catch can set up is its fully water tight.
i have one of these on mine and it does a great job, my oil consumption is down except rear main still leaks.
needs more curry
0272593533
0272593533
Do you have contact details for them?
matt
matt
I have 340km untouched internals and just unplugged the crankcase breather from the air intake and vent it down near the chassis. Plugged the air intake side obviously. Works great only concern would be deep river crossings i guess
- mud_slinger
Amma Motors
* 03-366 0454
19 Horatio St Christchurch 8011
* 03-366 0454
needs more curry
0272593533
0272593533
Cheers - any idea of cost?
- mud_slinger
um i couldnt tell you, mine came with the kit attached, they know a hell of a lot about the ol isuzu tho.
you'd have to give em a call just hope they still make the kit
needs more curry
0272593533
0272593533
