help needed asap in spreydon chch 10bucks cash
need to get this lada goin it wants to go its been sitting fr a few months it was running when i parkd it i dnt know what it needs maybe spark plugs are dirty? if you can get it going tonight ill give you cash want to take it out tommorow im no mechanic it is something simple anyone keen on quick cash txt or ring 0274454326 cheers
Re: help needed asap in spreydon chch 10bucks cash
have you tryed pouring a little petrol down the carb when trying to start it? Or maybe even tow starting it?
i sprayd the air intake thing it wants to fire
It'll probably fire up and run if you tow it behind another vehicle and crash start it
peice of shit i tryd towing it the back wheels dont spin.tried towing with the bighorn back wheels on lada just slid
- ClassicCruiserSpares
- Sausage Shack
Take the hand brake off
Last time you used it before parking it up did you have it in water?
best you free the rusted up brakes before you go anywhere?
yeah peice of shits been sitting there for a few months cause i got a real truck now it doesnt like me
Jack the back up, take wheels off, hit drum with large hammer around the outside.
If they free up, tow start at speed in 3rd gear.
ill give it a go in the morn i geuss
sibainmud wrote:Jack the back up, take wheels off, hit drum with large hammer around the outside.![]()
like he says or you can try it without step 1 and just tow it fast and dump the cluth a few times in 3rd and see if it lets go or rips the linings off the shoes
Sadam_Husain wrote:sibainmud wrote:Jack the back up, take wheels off, hit drum with large hammer around the outside.![]()
like he says or you can try it without step 1 and just tow it fast and dump the cluth a few times in 3rd and see if it lets go or rips the linings off the shoes![]()
Hard work towing it with back wheels locked up
sibainmud wrote:Hard work towing it with back wheels locked up![]()
Fark your right
better retract that last gem of advice
It's a Lada, push it over a cliff,
You bought a Hilux.......That man deserves a D.B
ethan loves toyota wrote:yeah peice of shits been sitting there for a few months cause i got a real truck now it doesnt like me
mylux wrote:It's a Lada, push it over a cliff,ethan loves toyota wrote:yeah peice of shits been sitting there for a few months cause i got a real truck now it doesnt like me
Put the DB in the lada... then push over cliff,
Give the Hilux owner a Speights!
juz wrote:mylux wrote:It's a Lada, push it over a cliff,ethan loves toyota wrote:yeah peice of shits been sitting there for a few months cause i got a real truck now it doesnt like me
exactly..
Sadam_Husain wrote:sibainmud wrote:Hard work towing it with back wheels locked up![]()
Fark your right![]()
somehow I was thinking shove it in gear push the clutch in and away we go and dump the clutch when were up to speed
better retract that last gem of advice![]()
Lubrication Specialist
Lubrication Engineers
people with nil mechanical aptitude should just take the bus
I mean really, thats like owning a guitar and never learning to play it ?
Landrover 4 Life - Best 4x4xfar
step 1 = check spark (good blue arc)
step 2 = check fuel (check fuel filter)
step 3 = check air (remove air filter)
those 3 items and good compression is all a motor needs to fire up... diesels get a little more complicated
dont forget timing for all these 3 things to work
muncha wrote:dont forget timing for all these 3 things to work
this is assuming the above, was parked when running well and then left for awhile.. timing shouldnt be a problem unless someones fiddled with the dizzy
