Terrano problems
Terrano problems
Hi All,
I have a few annoying issues with my terrano 1991 2.7TD Auto
First is the annoying auto lockup. It loves to stay in "5th" when I put my foot down approaching a hill. No matter what trans mode it is in, turning overdrive off just makes it ring its nuts out.
I have run the diagnostics and am getting no error code so I assume it is a factory flaw?
I have seen this post for making the lockup more controllable:
http://npora.ipbhost.com/index.php?show ... #entry6639
Has anyone done this mod?and any pros and cons?
Second is the rev gauge works when you start up and occasionally changes when you are driving but only to another fixed position.
Any ideas?
Third issue is when you rev the motor from idle it seems to take ages for you to hear the motor (as revgauge) to return to idle revs, about 10 seconds.
In traffic the truck surges with no gas pedel every now and then if that is related.
Basically the truck is dead stock so any help on things to remove or watch out for outside of general servicing would be much appreciated.
Paul
Any ideas?
Paul
- skid
- Tyre Man
Re: Terrano problems
sometimes it can be overlooked, but I think the Terranos have another switch whick holds the trans in gear
check for that button
toominator
- Bush Crasher
The rev counter thing isn't just the needle drooping and dragging on the dial surface is it? The needles on the older terranos seem to be made out of shit that bends when it gets hot.
You can bend them back if you're careful, take the steering wheel surround off, unscrew the plastic cluster surround and remove and then take the plastic front off the cluster
toominator wrote:The rev counter thing isn't just the needle drooping and dragging on the dial surface is it? The needles on the older terranos seem to be made out of shit that bends when it gets hot.
Something so simple, gave it a bend and seems to have done the trick. Thank you
For the trans, I tried in all modes and seems that it still does the same thing with overdrive on and about 85km/h you put your foot flat on a hill and it stays in the somewhat 5th gear. It blows out a bit of black smoke and slowly gets hotter.
Any other auto terrano owners with the same problem or had teh problem?
My work partner went through the same thing,
There is a temp sender buried deep inside, that tells when it is hot and cold (apparently they don't lock up till they are warm),
you have to reset fault code and find the wires and put a resistor in. There is a voltage range where everythings goes sweet. I don't have all the info, but i'm sure someone will.
sibainmud wrote:My work partner went through the same thing,
Ph 0212078472
Ph 0212078472
Thank you, looks like something to do this weekend.
My terrano does the same thing!! be interesting to see if the resistor thing works! might give it a try this weekend, also my old mans terrano does the same rev surge thing? id be interested to see if any one has any ideas
For the surgeing check the filter in the injector pump to find look under the power sterring pump.
You should see a 17mm bolt remove it BECAREFUL it has copper washers on both sides.
Move the pipe to one side useing a bic pen push it in the hole you should have a small spring on the end of it.
Do the same thing again with the pen and you should come up with a small filter about the size of the tip of little finger this could be all gunked up.
Give it a clean up and see how it goes.
Put it all back together oh dont forget to aneel the copper washers so they reset diesel proof or get new ones.
Terrano TD 2.7 and a ssangyong Rexton
Hi,can you please confirm the colours of the bands I seem to get 680ohms?
slo_mo wrote:Hi,can you please confirm the colours of the bands I seem to get 680ohms?
brown black black 100ohms
Ph 0212078472
Ph 0212078472
slo_mo wrote:Hi All,
Any ideas?
Paul
Hey Paul,
Its pretty cool that post I made on Npora all those years ago is still getting used
The mod is awesome, DO IT!!!!!
Used in conjunction with the hold switch, its much better up the hills
The idle one is odd. My brothers Mistral (same motor) was doing something similar. Will ask what the fix was
kiwipete wrote:slo_mo wrote:Hi,can you please confirm the colours of the bands I seem to get 680ohms?
Hi, sorry for all the questions. Do the other colours (white and blue)
mean anything?
slo_mo wrote:kiwipete wrote:slo_mo wrote:Hi,can you please confirm the colours of the bands I seem to get 680ohms?
mean anything?
No need to worry about those other colours, any DSE or Jaycar store etc will have them.
Ph 0212078472
Ph 0212078472
DieselBoy wrote:slo_mo wrote:Hi All,
Any ideas?
Paul
Hey Paul,
Used in conjunction with the hold switch, its much better up the hills![]()
The idle one is odd. My brothers Mistral (same motor) was doing something similar. Will ask what the fix was![]()
I've unplugged the kickdown switch, but the lockup switch still plays tricks on the computer. It seems that if its unlocked for too long then it wont lock up again and needs to be reset?
Hi, been running with the switch for a couple of days now and say do it if you have not already.
I useually leave teh switch on and turn it off for when I just need to,then right back on again. So no issues for me yet, probably more so how you use it.
slo_mo wrote:Hi, been running with the switch for a couple of days now and say do it if you have not already.
I take it you are talking about the torque convertor lock up. This does not lock up all that often when operating correctly, mainly when cruising at consistant speed/revs. Running it locked up most of the time will burn out the convertor and ruin your box. If it was slack and not working right I would have started with oil change (fully pumped) and new filter then looked at other repair options, stuff you are doing is just hidinmg the symptoms not fixing the problem.
meatc wrote:slo_mo wrote:Hi, been running with the switch for a couple of days now and say do it if you have not already.
Dude, read the thread first
The modification dissables the lock up
Hey, Kiwipete. This resistor mod... Is that basically to ypass the transmission temp sensor in order to get the torque converter to lock up?
My Teranno TD27 used to work great. As you say, lock up would not happen until the eng/trans was completely warm. However, over a period of time, the lock up seemed to work a bit less often and now won't work at all. I do understand that I might have an actual transmission problem (big$$
) but want to investigate a few things first. Does anyone have any experience with this problem?
So does this resistor basically bypass the temp sensor to allow lock up? You also mention having to reset the fault code. How is this done?
Dieselboy, I have read through you posts in this thread, and also where you posted the original mod (even though all the pics are gone now) I understand the mod, how it works etc, it basically means that if my lock up was working, I can manually unlock the torque converter.
Has anyone thought about or tried running a live wire (ie 12volts via a fuse) to a switch in the cab, then to the lock up solenoid? Unless it's way too far up the clever-stupid curve, in theory, it should mean simple manual control of the lock up. Obviously it would be pertinent not to lock up the torque converter stupidly, at low speeds/low gears etc, otherwise the results would be obvious.
Please let me know your thoughts guys. Kiwipete, if you could answer my couple of specific questions I'd be very much appreciated.
kiwinoz wrote:Hey, Kiwipete. This resistor mod... Is that basically to bypass the transmission temp sensor in order to get the torque converter to lock up?![]()
Yes you are right
Nope, that was Simon.
No problems.
Ph 0212078472
Ph 0212078472
kiwipete wrote:kiwinoz wrote:Hey, Kiwipete. This resistor mod... Is that basically to bypass the transmission temp sensor in order to get the torque converter to lock up?![]()
Yes you are rightYou also mention having to reset the fault code. How is this done?
The fault reset was on an R 50 Terrano.
Sorry for any confusion.
Would it be possible to put the lockup switch in the wires to the temperature sender, instead of to the lockup solenoid itself?
Im thinking of this to try and get around the tcu not engaging lockup after a while with it unlocked. If that makes sense.
Hey thanks for your help guys. I will try the resistor mod and hope that allows me to get lock up. From there, assuming it works, I'll rig up the switch so I can select whether ZI allow it to lock up or prevent lock up.
Cheers.
Cheers.
Mmmm... Adding the resistor hasn't got my torque converter to start locking up again...
But I haven't reset the error code, as was mentioned.
Can anyone please tell me how to do this?
Can anyone tell me how to reset the error codes on any other sort of model?
help would be appreciated
Lockup switch mod is working perfectly on my mistral 96.
Thanks Dieselboy.
Thanks Dieselboy.
