some work needed before cert
driftah
Stropper
Post by driftah »
seeing as you can't have any modified steering components welded I need a new steering shaft to keep the cert man happy
Am I best to get one custom made or can I mix n match bits off something else? 87' lux with surf power steer mod, Im keen to know what others have done that meets the new rule
Also need to have the driveshaft welds checked + shafts balanced
who would you recommend in chch for this?
snork
Re: some work needed before cert
Post by snork »
what new rule?
Fakey
Post by Fakey »
Youll need a collapsable section in your new steering shaft. When I put p/steering in my 40 I got 2 sets of LN130 surf steering shafts. Used on of the collapsable ones an the other 2 solid ones an got them splined to fit together
Cant find a better pic sorry
Didn't barbie drive a jeep??
muncha
Post by muncha »
circle track engineering on parkhouse road are good for driveshafts
shortylux
Post by shortylux »
Cant help re where, but you are allowed to mix and match parts. I had shafts from three different gens of hilux to make mine work.
Good luck.
COMILUX
Post by COMILUX »
Hey mate, front drive shafts factory ln130 and rear drive shaft was shortened and ballanced profesionaly by ms coombs engineering on st asaph st so shouldnt be a prob.
027 337 0579
