Transfer box issues - series3 A-frame towing
Posted: Sat Nov 13, 2010 3:32 pm
front prop shaft is able to be turned freely with transfer box in normal range, but is locked in neutral or low range........
any suggestions?
I have pulled apart both free wheeling hubs and aside from one broken spring they are both working fine, which has lead me to this...
why is the rear prop shaft connected to the front one when the transfer box is in neutral or low, but not when its in normal....
regarding towing the vehicle on an A-frame - should it be in high range with the gearbox in neutral so that the front prop shaft and front diff are not turning?
or should both boxes be in neutral with all propshafts and diffs turning ??
considering installing free wheeling hubs on the rear as well to make life easier.......
Any comments appreciated !
P.s. If anyone out there has a pair of AVM 10-spline hub lockers for sale let me know !
any suggestions?
