80 series cruiser LSD diff head wanted.
Anyone got one or know where to get one? Needs to be LSD.
Re: 80 series cruiser LSD diff head wanted.
Try bundy from rallys..But may only have 70 lsd's
Don't have 4wd.
Is it an 8" high pinion one?
Not sure what the difference between 70 and 80 diffs but apparently the 80 is stronger.
What are ya planning on using it for?
Didn't barbie drive a jeep??
Putting it in the rear of the trials truck, we are getting sick of blowing hilux diffs.
mudnutz wrote:Not sure what the difference between 70 and 80 diffs but apparently the 80 is stronger.
They are pretty much the same diff
Are you looking for an LSD out of the rear of an 80 series. I have one of those. $500.
G
G
A 80 diff (rear )head is larger than a hilux one no? it wouldnt fit into a lux housing....... and i dont think the 80 front had a LSD? (they are effictively the same size as a hilux rear...)
- cool__bananas
the rear of an 80 is the same as the rear of a 40 and 70 etc? just the big toyota diff?
Jungle wrote:Are you looking for an LSD out of the rear of an 80 series. I have one of those. $500.
G
Do you know what ratio it is?
I will go and check. Suspect 4.1.
It was behind a 1HDT engine with 5 speed box.
Jungle
Jungle
Checked it out. 4.1:1 it is.
Jungle
Jungle
I have a LSD carrier as removed when I fitted my ARB air locker to my FJ 70, and it was a good working LSD when removed 12 or more years ago, It's sitting in the ARB box in the roof of my garage , opps I mean junk shed
MUST HAVE A CLEAN UP ONE DAY,
FITZY.
FITZY.
Trying to find one a bit closer to home, cheers guys.
