Hi guys
new boy to the site
got a problem with my 80 series landcruiser.
ignition lights flicker on while driving
anybody got any idea what it could be.
jase99
landcrusier ignition lights
Re: landcrusier ignition lights
Bad earth to instrument cluster.
Loose connection to instrument cluster.
Loose bulb in instrument cluster.
Bad battery terminals
Bad fuse able links
A Something is loose?
Calvin
Bad fuse able links
Calvin
or the alternator is on the way out. check battery connections first.
yup check your battery terminals, if they are loose then you may be buggering your regulator in the alternator.....
